Bosch module burn up.
  • #43080
    Taken from a dishwasher (SGS45E08GB/45 FD8406) 😯
    I’ve never come across such a burn up on a Bosch module before and was wondering if anyone else has come across similar?
    It’s hard to put a finger on the cause but the majority of burn seems to emulate from the centre relay perhaps? It’s then burnt through the ribbon cable and fused the microprocessor?
    In any event I’m not at all sure if a component within the machine had caused it. Usually isolated areas of PCB damage can be traced to external component failure but sadly I fear not in this case. 🙁
    #275994
    EFS
    Re: Bosch module burn up.
    Martin wrote:I’ve never come across such a burn up on a Bosch module before and was wondering if anyone else has come across similar?
    I had an identical one last week but a bit more serious.
    Didn’t bother to note the numbers as it was going in the skip outside but it was a 45cm model.
    The only other fault was the spring loaded door latch had self destructed so perhaps water got in with the door not properly closed.
    Steve
