Re: Bosch motor faulty?
burton1972 wrote:Hi. Done a continuity test on a bosch motor to see if its faulty. Have readings on connections 1&2 and 5&6 but no reading on 3&4 and have tested the brushes as well, which are ok.
Can someone let me know the diagnosis please and what i can do?
you have 6 connections
2 for armature
2 for field coil
2 for tachometer
the armature and field give a very low reading but the tacho is higher so may give the indication it is not there. use a higher resistance range and see if it is there.
if 3 {e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} 4 still are not there you need to find out what the do. you can rule out armature by testing from the brushes to the plug to see where it goes
