Bosch/Neff dishwasher heat pumps
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch/Neff dishwasher heat pumps
  • #90571
    Houseproudtim
    Hello All, Has anyone had the same problem with un-reliable heat pumps from the german lot? your lucky if you get 2 years before they blow up, and I’ve had replacements only last weeks.
    At £125 its a bit strong plus labour for customers to undertake the repair. 😕
    #445238
    Re: Bosch/Neff dishwasher heat pumps
    These tales of woe are commonplace and suffered by many. If you use the ‘Search’ box and type heat pump a whole raft of moans and groans are to be seen spanning recent years. Changing these is a risky business as so many factors can come into play once the repair is completed and paid for by the customer. Usage, water leaks in the base, sluggish pumps, water starvation and excess voltage can all lead to premature failure. Giving a 1 year service guarantee and the pain truly kicks in as many only last months as the testamonies show. Bosch, Siemens and Neff dishwashers are a serious financial risk to the sole trader so don’t even think of doing work on the cheap on these heaps of pooh. 🙁
    #445239
    nomadPaul
    If you work/live in a hard water area then keeping the salt topped up is imperative , even when using all in one products. Its also worth advising the customer to use a dw descale every 6 months or so. Nearly every heat pump that goes open circuit (with a dry base…. ) will have a limescale build up on the inner side of the heater and a burn mark the other side causing the o/c condition.
    #445240
    funkyboogy
    was at a customer last week Gorenje heat pump dryer
    situated outside in a garage
    he has to use an electric heater to heat up garage before he can turn on his eco friendly dryer lol
    what next solar powered fridges
    #445241
    Houseproudtim
    Thank you guys.
