Hi i’ve got a typical bosch/neff dishwasher that is only half filling, unfortunately the model No. has been scraped off.
The problem is the ‘heat matrix’ metering tank is only getting about 1cm of water into it. I mean the metering tank on the right hand side of the main fill metering tank. There are 2 solenoids on the ‘salt unit’ and the pressure chamber switchs have continuity through them.
Has anyone come across this problem before? I’ve had machines that have filled the ‘heat matrix’ metering tank and not emptied before but never one that hasn’t filled.
Hope that makes sense. Any ideas will be gratefully received
thanks rob
