Bosch, Neff, Siemens Showing 1 min left syndrome
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch, Neff, Siemens Showing 1 min left syndrome
  • #69844
    On many different BSH branded models of both dishwasher and washing machine the programme appears to complete all but the last 1 minute shown on the time counter. And, without exception, relates directly to a ‘time-out’ error (of some sort) that the programme module has detected at some point during the cycle. The programmes microprocessor circuitry somewhat basic in not specifying an error code but instead just displays the number 1 (-1) or (01) in the window.
    In the case of a dishwasher it could mean one or more of the following problems have occurred: –
    Fill time-out
    Drain time-out
    Blockage in water fill system
    Not heating
    Anti-flood switch tripped
    Turbidity sensor (if fitted) fault
    For washing machines and some washer dryers then almost always it refers to an earth leakage problem associated directly to the motor. So an insulation tester is vital in identifying any failing there. Likewise the heater needs checking.
    In some (isolated) cases a motor fault can damage the fuzzy logic circuit within the control module (PCB) though. And only after you have successfully repaired the motor fault does that issue become apparent and replacing the PCB the only cure.
    Open circuit heater – Usually completes cycle OK but your customer will very often tell you it took far longer than normal to finish.
    #376160
    jimca007
    Re: Bosch, Neff, Siemens Showing 1 min left syndrome
    thanks for the info had one in my area with this for a while but since it doesnt seem to effect performance i’ve just let sleeping dogs lie
    #376161
    jimca007
    as an update happened to be back to that bosch was indeed low ins on the wash heater ! job done thanks again Martin
    #376162
    lee8
    So on a dishwasher, that basically is designed to fill, wash, heat and drain and receives an 1 in the display it could be that it does not fill,wash, heat or drain, oh and possibly leaked.
    Usefull. Thanks:lol:
    Sent from my GT-N7000 using Tapatalk 2
    #376163
    lee8 wrote:Usefull. Thanks:lol:
    You can learn something new every day on here Lee except perhaps how to spell eh? 😉
    #376164
    lee8
    If l could spell i’d be a true genius.:lol:
    Since you know my flaw, what is your little inperfection called.;-)
    #376165
    senseib
    Hi I have a bosch washer dryer in with the same error display – washer heater element seems ok as does the dryer element!
    I have tried to cancel the error code by disconnecting the motor and then pressing one of the other buttons as i rotate through the programmes but won’t do it – any ideas on how to cancel it?
    If it’s not the heater element is it likely to be a motor fault ?
    #376166
    senseib wrote:Hi I have a bosch washer dryer in with the same error display – washer heater element seems ok as does the dryer element!
    The thread is meant to be informative ONLY. Any problems with these symptoms should be posted individually in Trade Tech. In this case I suggest you ask the question again and perhaps far far better to specify what the model number (ENr) number is as well? 😉
    #376167
    senseib
    Solved it tare – thanks for your help!
    #376168
    Beever
    I have had a number of Bosch WFO type (with the small RED time remainder screen) finish with 1 min in display, this was caused by intermittent heating. The fault has been with the NTC. I have done around 20 now. Keep an eye out!! 😀
