Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch new format SBV50E10 wierdness – wont work unless you..
- This topic has 7 replies, 5 voices, and was last updated 12 years, 4 months ago by
gandh1.
December 10, 2013 at 12:20 am #78531
gandh1
Participant…open door during its drain phase.
start it up, drains, then activates circ motor but doesn’t take water in, senses its empty so then goes back to draining. continues this then the no fill light coming on.
weird thing is if you open door during the draining phase, it will start to fill.
have already replaced reed switch to find no change in symptoms.
already have pump and would have tried that but its the extra deep carcass, which means the pump is nigh on impossible to replace without full strip down, as its sitting hard on base.
am wondering if its possible theres an issue with the door lock sensor, has anyone else had any similar issues?
December 10, 2013 at 2:54 pm #406017electrofix
ModeratorRe: Bosch new format SBV50E10 wierdness – wont work unless y
not sure but,
From what i have read etc the pump is 3 phase ( therefore has 3 wires going to it) they use the current going to the pump to sense when unit is empty. if pump is getting worn and jamming it will draw more current and therefore board will not sense it is emptyyou may have to try the pump change to find out
December 10, 2013 at 3:10 pm #406018Martin
ParticipantRe: Bosch new format SBV50E10 wierdness – wont work unless y
electrofix wrote:not sure but,
From what i have read etc the pump is 3 phase ( therefore has 3 wires going to it) they use the current going to the pump to sense when unit is empty.Spot on Dave. Below is an example of its wiring to the power board….
December 11, 2013 at 11:50 am #406019gandh1
“vorsprung durch รผber technik” then
May 28, 2014 at 8:22 pm #406020CARLJONESDAR
I have the same problem on the same model. Did the new pump fix the problem?
November 15, 2014 at 8:08 pm #406021eng14
hi all had the same fault on friday,do you mean the drain pump or wash pump,richard. ๐
November 15, 2014 at 8:27 pm #406022Martin
The drain pump.
November 15, 2014 at 8:34 pm #406023eng14
๐ thanks martin,stupid little pumps far worse than the old type,richard
