Hi Guys Hope you can help me out
Went to a Bosch washer today. no mtor action. Thought most probably
brushes. When diconnecting the motor noticed motor plug wires come adrift. as they are all orange not sure where they all go. 6 pin motor type. Model No WFL2063 FD 8305. Tried unsuccessfully with bosch to get a wiring diagram. Will sell me a loom though. Cheers Mark 😕
As far as I recall Mark the motor plug wire connections coincide with their respective module terminal plug connections. (i.e 1 thru 6 on each plug wired the same) 😉
A simple continuity meter check on each wire to confirm you have them in the same order :tup:
