Re: Bosch No Display
Hello mate I had similar on my wfr2866, now it seems on these models that any component failure stops the main board lighting up. Has power getting there. I found the flow sensor at fault with mine. The usual suspects were fine and in the end I just went round disconnecting the smaller components. Checking the board after disconnecting each part individually.
I thought it was a bit strange at first but it worked.
Also check for moisture on the board
