bosch no fast spin
  • #35723
    abbots
    hi guys,
    bosch WFL2463GB/12
    customer has already had one engineer out from another company to look at this.
    She says it is not getting the clothes dry enough on a spin.
    The other engineer couldn’t find a fault, and to be honest, i can’t.
    the carbons seem fine, the pump is clear and runs ok.
    It doesn’t seem to be doing the very last part of the spin cyle, when the machines speed picks up and does the 1200 spin.It seems to be running at half spin speed only.
    Any common faults i have missed?
    thanks.
    john
    #247768
    Re: bosch no fast spin
    abbots wrote:Any common faults i have missed?
    Heater open circuit I expect….?
    Did she also tell you it takes ages to complete a wash, longer than it used to? 😉
    #247769
    abbots
    thanks buddy,
    no mention of taking longer and the problem is intermittent.
    It seems to complete the cycle fine, just not spinning correctly.
    john
    #247770
    philfish
    unbalenced load? just a thought.
    #247771
    abbots
    tried different loads and tried when empty,still the same.
    john
    #247772
    abbots wrote:It seems to complete the cycle fine, just not spinning correctly.
    Has is got a Siemens or FHP motor in it? Have you checked the heater?
    #247773
    gegsy
    FYI – Cycles max spin speeds are –
    Cottons +Linens 1200rpm
    Easy care 800rpm
    Delicates 600rpm
    Woolens 800rpm
    Rinse/Freshen Up 800rpm
    Spin 800rpm
    HTH
    abbots
    cheers greg
