Bosch no final rinse or stuck in cycle??
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch no final rinse or stuck in cycle??
  • #84873
    Leafy
    Hello everyone, I’m new to the forum so please excuse me if I am covering old ground, and repeating earlier posts.
    My Bosch SGS5312GB is playing up.
    Symptoms (it is doing one of two things)
    1. Does not operating final rinse (and I think circulation or drain pump continually runs, but cycle does not progress.
    2. It sometimes overfills
    1. Machine clean, no blockages in filters, impeller, drain hose or inlet
    2. New inlet solenoid installed
    3. Plenty of heat in appropriate cycles
    4. Reset works each time it is activated, and ends cycle
    5. Anti float works when machine overfills, or when I activate it (lifting rod) to nudge it within cycle when its stuck
    6. Drain pump works every time
    7. All chambers clean, clear and working
    8. Pressure chamber expands normally
    9. Detergent dispenser broken on door, we throw the tablet in currently
    10. Water is let into the machine with no issues
    My suspicion is that the pressure chamber microswitch is at fault.
    I have observed that the pressure valve expands and activates the switch, and changes the operation, but many a time the small black switch element underneath remains stuck in the body, leaving the blue arm permanently pushed out, and I imagine the microswitch being permanently activated., and confusing the machine/computer.
    I figure changing the microswitch will fix it. Anyone concur?
    Cheers
    #427048
    Re: Bosch no final rinse or stuck in cycle??
    part number 263185
    for part breakdown go here
    http://www.bosch-home.co.uk/store/spareparts/search
    sound likely but its a suck it and see type of fault
    also check wiring as it goes into door. a lot of dishwashrs break at this point
    Leafy
    Thanks Dave
    I’ll check the wiring.
    Funny I did suck and see on the pressure chamber to make sure it inflated (lol)
    Mark
