Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Bosch – No water / Constant Pump / Opening Door doesn’t stop
- This topic has 5 replies, 3 voices, and was last updated 14 years, 11 months ago by
Gasman2.
April 26, 2011 at 10:08 am #62420
Gasman2
ParticipantHi
Bosch SGS65L22-GB/07
Was working fine.
Then went to start a program with door open (needs to be to access the buttons) – as I selected the program, it started to run – even though the door was still open.
But although there is a pump running, there is no water coming in. The pump keeps running even as the program counts down and then gets to zero – it keeps running.
Opening the door doesn’t seem to make any difference to the pump running or the program counting down.
Only way to stop the pump is to turn it off.
Tried pouring water into the bottom and this is pumped out.
Any ideas what could be wrong?
Many thanks
April 26, 2011 at 10:11 am #350061iadom
ModeratorRe: Bosch – No water / Constant Pump / Opening Door doesn’t
You may have a flooded base. Unplug, drag it out and tilt it.
If water runs out from underneath you may have an internal leak or an oversoaping problem.
April 26, 2011 at 10:37 am #350062Gasman2
ParticipantRe: Bosch – No water / Constant Pump / Opening Door doesn’t
Thanks for the speedy reply! Seems like you’re correct. Just tilted it and the floor is now quite wet! Looks like at least a good mug full of water – maybe more, and I didn’t tilt it for too long.
So – now what?!
April 26, 2011 at 10:49 am #350063Gasman2
Just been mopping up the water! More like at least a pint, possibly quite a lot more.
April 26, 2011 at 1:26 pm #350064Gasman2
One further thing…
The machine was repaired just before Christmas – is it possible that there’s been a slow leak from then – or a slow leak that’s got worse?
They also apparently left the machine in their unheated workshop during a period when we were getting -10° (and colder). Their pipes and testing rig froze – so presumably my machine did too. Could this have caused damage that’s resulted in the current leak?
Many thanks.
April 26, 2011 at 4:21 pm #350065Martin
Gasman2 wrote:The machine was repaired just before Christmas – is it possible that there’s been a slow leak from then – or a slow leak that’s got worse?
I’m certain that is the case…YES!
