Bosch not cleaning on lower rack
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch not cleaning on lower rack
  • #68789
    Footman_2
    Hi, I have a BOSCH dishwasher SGS43A18GB/27. It is not cleaning well on the bottom rack. The lower spray arm has been replaced with new. The water switching motor has been tested works fine. The control panel has been changed once for the recall fire hazard and then again for another because I suspected it was causing this problem but problem still there (at no cost to me). Engineer said it would cost me over £100 to find the cause. All pipe work and water matrix are clean. However it is over 10 years old and if the fault is expensive to repair I will give up on it. Any ideas?
    #372760
    Re: Bosch not cleaning on lower rack
    Footman_2 wrote:The water switching motor has been tested works fine.
    That by definition has to be a contradiction in terms. Clearly the water to the bottom spray is not nearly as effective as the top from what you say therefore that device has to be faulty. In fact I would say from vast experience that that is exactly what is wrong here and by only fitting a new Heater Unit (Part No 483058 @ £100.64) will cure the fault.
