Bosch not empting at end of cycle
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch not empting at end of cycle
  • #90846
    Pwcomp
    Bosch Exxcel Dishwasher
    SGS45E62GB/64
    hi there i have the above dishwasher and as the post heading says its not emptying at end of program. the pump is OK, i have operated via a red float level on side of machine, and it emptied fine, so assume its the program its self that is not sending the command to start the empty? If some one can point me in the right direction it would be a great help.
    #446190
    Re: Bosch not empting at end of cycle
    Most likely reason is that the pump is worn and needs replacing. That it appears to drain out fine with the red float manual intervention but when it attempts to drain very hot rinse water it seizes up.
    The other possibility is that the drain outlet is partially restricted somewhere along its route causing the program to ‘time out’. It only has some 60 seconds to drain so any restriction can result in the effect you are experiencing.
    #446191
    timdowning
    Does it heat?
    #446192
    Pwcomp
    Martin wrote:Most likely reason is that the pump is worn and needs replacing. That it appears to drain out fine with the red float manual intervention but when it attempts to drain very hot rinse water it seizes up.
    It’s a brand new pump fitted and dumped pretty quick. Thanks for you reply.
    #446193
    Pwcomp
    timdowning wrote:Does it heat?
    you know I’m not a 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure but I don’t think it did.
    #446194
    Pwcomp
    Pwcomp wrote:
    timdowning wrote:
    Does it heat?
    I just checked the heater element it had a resistance of 2.9 Mohms? Is tha t good or bad seems high to me but I have no idea what it should be.
    #446195
    Around 23 Ohms.
    #446196
    Pwcomp
    Bit higher than it should be then. ?? Thanks.
