Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Bosch not filling
- This topic has 6 replies, 4 voices, and was last updated 21 years, 7 months ago by
admin.
August 17, 2004 at 11:54 pm #6054
KeymasterI’ve an SG16612GB/07 FD 8103 740068. Has been a little unreliable recently but now given up the ghost. The programs run but very little water enters the machine and as described elsewhere in the site the tablet sits soggily on the nearest pan/dish to the trap door. The inlet valve appears to open for a brief time at the begining of the cycle but nowhwere near enough time to ‘fill’ the machine. If I pour some water in then the machine runs happily but once it drains, doesn’t refill for the rinse.
Any clues? I’m in Norwich if anyone in the trade wants to recommend themselves to fix this!
Thanks.
August 18, 2004 at 12:48 am #115345Penguin45
ParticipantHi HTDD,
Your machine is an SGS6612GB/07? The most likely cause of your problem is a blockage from the fill matrix on the left side down the hose to the machine’s sump. It’s not a difficult fix, but rather awkward!See who responds from Norwich post codes is the easiest solution, or check the “Directories” section on the left.
Penguin45.August 18, 2004 at 7:10 am #115346Martin
ParticipantRe: Bosch not filling
Yes the SGI6612GB/07 is the fully ‘integrated’ version of the SGS series, and yes the pipe from the Pressure Chamber to the sump will be blocked with fat deposits need a clear out.
It is accessible from inside the tub (a 20mm aperture to the L/H/Side) can be cleared with a long thin ‘bottle brush’ 😉 A better fix is accessing the side panel, removing the pressure chamber, cleaning and refitting (better left to the experts though)
August 21, 2004 at 7:14 am #115347admin
KeymasterRe: Bosch not filling
Hi Htdd,
Since there has been no reply I assume you have sorted yourself out, If you still have problems give us a ring on Monday at the office speak to Yvonne she will arrange a service call.
Our contact details can be found on
http://www.bnsservices.co.uk
EMail = service@bnsservices.co.ukRegards
DennisSeptember 22, 2004 at 7:45 am #115348Martin
paulster wrote:I have just fitted a Bosch dishwasher but have encountered a few problems. All pipes are fitted correctly, but I cannot get water into the machine on any program.
The supplying hose is clear and water is under pressure to the machine.Any help appreciated.
Model is SGS4012GB/07
FD 7712Thanks
PaulPaul,
There may be a number of reasons for this and in order to decide we need more information. Such as : Does the drain pump keep running? Is the base flooded? Etc Etc
March 13, 2007 at 8:48 am #115349Fugazi
I have the same machine recently brought second hand, I have seen the machine working but upon plumbing in I have the same problems as paulster. The pump sounds as if it is running, but the water does not empty from the washer and I cannot select any of the programs. I have checked the drain hose and water does come out of it, but only very slowly and in spurts, I’ve been onto the Bosch site to see if I can find a manual but the machine isn’t featured anymore. The email address they give you to contact them doesn’t exist!!
Any help would be appreciated.
Cheers
March 13, 2007 at 8:53 am #115350Martin
Take the pump cover off, check the pump is not blocked, remove the rubber valve and check that etc etc. There’s plenty mention all over this site on the subject using the ‘search’ facility…… 😉
