Re: Bosch or Makita SDS hammer drills?
Hire or buy? If you hire, try to find an independent hire shop, as I found their prices worked out much cheaper than the national chains.
I hired an 11kg Bosch SDS-max demolition hammer recently to remove 35 sq m of floor tiles from a concrete floor. Even with a tile chisel it was pretty much a couple of days’ work, with breaks, although I removed pretty much all traces of tile adhesive. Anything smaller and lighter would have been a nightmare to use. Only afterwards when my hands were knackered did I read HSE guidelines which recommend breakers should be used for no more than 1 hour per day to avoid vibration injury.
