Ok Personal problem.
I have in my own kitchen a bosch single oven Hbn5605 and a bosch induction hob pie645.
When they were wired in I researched the wiring online and through sparkis I know and all agreed that the oven and hob could be wired in tandem to a 6mm cable to a 40 amp dedicated fuse via an isolated cooker switch.
As far as I remember the oven is 3.5kw and the hob 6 or 6.5kw
Oven has gone wrong , no display lights etc but has power to the back so main board has blown.
I called up bosch 2 weeks back and this morning an engineer came out and said “ooh never seen that done before I am going to have to get in touch with our tech department and see if thats ok.”
which I suppose is fair enough but he did’nt even have the right board on board.
So question is .. Am I ok with both appliances being wired into the same circuit.
Ta John ovenless
