Bosch Oven Dead -HBN131150B/02 FD8502 001552
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch Oven Dead -HBN131150B/02 FD8502 001552
  • #77984
    grooster
    I went out to have a look at a bosch single oven and the customer complaining that the machine timer lights up but the machine will not come to life. I presumed the timer wasn’t set, so I tried to explain but to no avail. I went out to look at it yesterday and she’s correct.
    I switched the power off and re set the the time, it clicks but theres nothing else.
    Theres no fan, fan element or grill working. I’ve checked the cut out and cut in, elements and everything looks fine. I had a look at the selector switch and that looks fine.
    I’m presuming its the time clock but just a little unsure with the grill not working as well as the oven.
    If anybody can shed any light on this for me and give me a bit of advice before I order the timer, it would really be appreciated.
    Many thanks
    Nick
    #404088
    Re: Bosch Oven Dead -HBN131150B/02 FD8502 001552
    Timer needs replacing.
    #404089
    grooster
    Cheers Martin,
    thought as much.
    Regards
    Nick
    #404090
    ray.t
    I had one of these this week with a faulty selector switch, same fault timer set as normal but nothing would work.
    I took a gamble on the selector switch even though it looked ok but when I swapped them over and looked at it the first row of connections(nearest the fascia)had burnt.
    Cheers
    Ray
    #404091
    grooster
    Cheers Ray,
    I did have a quick look at the switch but you’ve got me wondering now.
    May order both, just to be sure.
