We have had this oven about 12 months and it is functioning well. Recently tried the Pyrolytic cleaning for the first time. The first time used Pyrolytic level 3. After a few minutes error E6400 appeared with message to press the On/Off.
Tried it again a bit later on Level 1 with the same result. Other than this is it is still working well.
We have had it fixed under warranty. E6400 is about a ventilation flap not opening when the oven heats up. Was happening about 4 minutes into the cleaning cycle. You could hear the motor turning that opens the flap via a cam, but it just kept cycling as it did not stop with the cam in the correct spot to keep the flap open.
