Bosch oven HBN131550B/02 Info
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch oven HBN131550B/02 Info
  • #72196
    repman
    I know its (still,second post) a long shot but has anyone got a diagram of this
    -perm cooling fan run and almost certain the selector switch wiring is wrong
    cheers jim
    #383804
    Re: Bosch oven HBN131550B/02 Info
    Give Bosch tech dept a ring. If they have a .pdf available then they can fax or email it you.
    #383805
    nomadPaul
    If you switch the oven off from the mains and then switch back on , does it take around 5 mins for the fan to start and then it continues uninterrupted ? From your description , I’d be betting that there’s a coupling behind the selector switch that has broken. Off the top of my head I think the part number is 420601……but don’t quote me on that ! Lol
    If the coupling is broke , the selector knob and selector switch don’t match up so what the knob shows isn’t the correct position.
    ………that’s if this model has the coupling. I havn’t any details to hand right now to confirm it but that’s my guess 🙂
    #383806
    repman
    got hold of bosch tech and managed to obtain a diagram but it was not very forthcoming.why do they have to be so protective?
    anyway job done
    thanks both
    jim
