Hello all
I have an issue with the oven above, the front door on the left side is slipping down, so i took out the bracket that holds the inner glass and removed that .
there is an arm each side that is connected to the hinges which close the door.
The left arm has come away from the outer glass door and it seems as some type of glue was used to hold it together. The right side is fine, and i dont dare try to fiddle with it,
based on this, im guessing the arms would have been glued (special oven glue) where the grey blobs are?
anyone ever tried to repair it?
i can get some special oveen glue sold online, but wanted to know if anyone else had the same issue
thanks
