Bosch oven is tripping RCD fuse
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Bosch oven is tripping RCD fuse
  • #101280
    gwynahad
    I have a Bosch oven HBN580651B, it tripped the RCD when was on for 30-40 minutes on fan 180C. The food was burnt on the top.
    Upon further investigation, it seems like the element heats up just when in “Oven Light” mode, and when on Fan Oven it doesn’t control the heat.
    It feels like the element is on whenever the oven is on, which is not correct. Is this a common fault? Has this been seen before?
    Thank you!
    Bosch FD-8808 00001
    E-Nr. HBN580651B
    Type – HTHB38
    #484166
    does sound like the relay on the control board has welded contacts
    the manufacturers answer is to change a £200 board but you may be able to source a relay and solder it in
    gwynahad
    Thanks Dave! will test the relay tomorrow and see if it is welded. If it is welded will see about getting a relay Vs a new motherboard.
