wae24060gb02 start, rinse, express lights flashing and the other 3 lights flashing, put it on spin which is fine, put it on fill and over filled, checked pressure chamber and pipes not blocked so thinking pressure switch but its a special was want to make sure, are all the lights flashing a code?
Dop
Simplest way to check if it is the pressure switch is attach a short length of air hose to it and a gentle blow whilst its filling. They are generally very reliable so I will be surprised if it is faulty.
