Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch Precision Washing Machine WFG-2420
- This topic has 7 replies, 3 voices, and was last updated 18 years, 6 months ago by
sandy_beech.
September 17, 2007 at 7:54 pm #30615
sandy_beech
ParticipantHi
This morning the washing machine operated normally with a full load. This afternoon I put in a new load and when I went to it this evening I was puzzled to find that the washing was still unwashed but the drum felt warm. I checked the powder and softener compartments to find they were empty. Thinking I was losing it I put in new powder and softener and switched it on. Just been out to it only to find that the same has happened again.
Any clues please gentlemen?
September 17, 2007 at 8:26 pm #227837Penguin45
ParticipantRe: Bosch Precision Washing Machine WFG-2420
Observation required……….
Does the drum turn seems to the obvious question.
September 17, 2007 at 8:47 pm #227838sandy_beech
I tried it on rinse and on cold but it looks as if the drum is not turning though it sounds as if the motor is turning slowly. I am going to try it again once the door has unlocked and I can get the washing out.
September 17, 2007 at 8:56 pm #227839Penguin45
Better have a read of this, then:
http://www.ukwhitegoods.co.uk/modules.p … ge&pid=156
September 18, 2007 at 3:27 pm #227840sandy_beech
OK thanks for that but now how do I attack the beast?
I have the machine disconnected from everything but not sure how to get the motor out. Last one I tackled had the motor on top – sooo easy.
Thanks again
September 18, 2007 at 3:50 pm #227841Martin
sandy_beech wrote: Last one I tackled had the motor on top – sooo easy.
In this case you’ll need to get on your hands and kness for this one as the motor is in the more usually position. Namely, remove the back panel and the motor is bolted to the casting at the bottom. Take the bolts out and you’re halfway there to sorting it……! 😉
September 18, 2007 at 6:01 pm #227842sandy_beech
Cheers guys – sorted. Well the motor is out and the brushes are knackered – one more than the other.
What is the best way to ensure that the belt tension is correct?
September 20, 2007 at 8:45 am #227843sandy_beech
Participantsandy_beech wrote:Cheers guys – sorted. Well the motor is out and the brushes are knackered – one more than the other.
Fully sorted and operational again.
Many thanks for the advice – one brush was to 3/16 long. The only place I went wrong was buying the brushes locally (the washing was stacking up) and paid £26-00 for the brushes (ouch).
