bosch pyro oven e6 fault
  • #93835
    happy chappy
    hi all this is my first post on the forum so hello
    i have a er6 fault on a bosch oven model hbn730520 this should mean that the door lock is faulty i have replaced the lock the door locks ok but after about 1 hour it brings up the e6 fault any ideas
    thanks all
    #455666
    Re: bosch pyro oven e6 fault
    as far as I can see (no tech access ) the door should only lock on the self clean programme.
    when you say the door locks is this only on the cleaning programme or on any other function ?
    happy chappy
    Hi Dave
    thanks for you reply yes you are right it only locks on self clean and only when the temp goes above 250c
    cheers stuart
