bosch s41e50w0gb/03
  • #88710
    mikehha
    hope someone can help I have the top light/tap and bottom light/rinse aid are on and I cant get the dishwasher to do anything there is no water in base and when you activate the flood switch the pump runs but nothing else. I cant even reset program .Do you get problems with water getting on to the side control/power card.
    #439122
    Re: bosch s41e50w0gb/03
    Well for sure your next move would be to check out that power board for surface component damage.
    #439123
    mikehha
    Just got back from hoilday, martin, so sorry for the delay. have allready checked board for damage and cant see any.but there has been water on the plastic case.
    #439124
    BSH-MAN
    D bus “Communication error” I suspect with 2 lights on. Power module, touch control module (if fitted) and door lock hall sensor can all produce this fault.
