Bosch S5444X1GB/23 Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch S5444X1GB/23 This topic has 4 replies, 2 voices, and was last updated 9 years ago by ChrisR. Viewing 5 posts - 1 through 5 (of 5 total) Author Posts March 28, 2017 at 7:24 am #90931 ChrisRParticipant Good morning. How easy or hard is it to change a motor to sump seal. Thanks. Chris March 28, 2017 at 4:32 pm #446506 MartinParticipant Re: Bosch S5444X1GB/23 It’s the normal tub off base system I apply. Is it leaking then? Are you certain the gasket is at fault and not tiny pin holes in tub causing a leak? March 28, 2017 at 4:37 pm #446507 ChrisRParticipant Re: Bosch S5444X1GB/23 Sorry Martin I think I’ve described it wrong. It’s the seal that the motor pushes into in the sump. Chris. March 28, 2017 at 6:06 pm #446508 MartinParticipant Re: Bosch S5444X1GB/23 No my fault Chris. You described it correctly and I read it wrong. All the same and for me it’s easier to lift the tub away but others will simply hinge the base away and fiddle a new grommet in. 30 minute job doing it my way. 😀 March 28, 2017 at 6:08 pm #446509 ChrisRParticipant Re: Bosch S5444X1GB/23 Thanks very much Martin Author Posts Viewing 5 posts - 1 through 5 (of 5 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
