A Bosch S5C27B (details below) won’t fill. Therefore it gets stuck at the initial fill stage. When turning it off and on at this point there is a faint “chonk” noise which may indicate a solenoid opening up. Some water gets in but not a lot.
Pumping out seems to be OK.
It’s just been moved which may have upset it. There is water in the pipes – a washing machine on the same pipework is working fine.
Is there a likely fault? If not, what would the likely charge be for a callout (in Lancaster).
Details:
E Nr. SMS6012GB/20
FD7603 810208
19603210211645310208
Type S5C27B
Hugh
