Bosch S6M30B top spray arm not turning
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch S6M30B top spray arm not turning
  • #13812
    mikeminty
    The machine is about 7 years old. Works fine apart from the top spray arm – it does not rotate. It’s free to spin and clear of muck so no water being pumped into it I presumed. Took out top tray, put a large jug in bottom tray and ran machine. Some, but not much watr in it – guess thrown up from the lower spray arm which works fine. So….. what controls the flow to the top one? Seperate pump? Solenoid controlled valve? Any advice before I start pulling it apart? Is there an on line exploded parts drawing that I can access? Thanks in advance, Mike
    #156820
    Dave_Conway
    Re: Bosch S6M30B top spray arm not turning
    mikeminty wrote:Is there an on line exploded parts drawing that I can access?
    Yes there is, it’s here:
    http://www.bshappliancecare.com/Bosch/boschspares.html
    Click on the “Quickfinder” link. You’ll need to check the model though as it is incorrect or incomplete, around the door, it should begine Enr……
    There is probably a motorised valve that directs the water to the upper and lower arms alternatively.
    Power off when checking please :zap:
    #156821
    mikeminty
    Thanks, I’ll check that out and see ……..
