Bosch sbv50e1.10gb17 fault
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch sbv50e1.10gb17 fault
  • #82219
    Jennytom
    Hi I would be really gratefull is somebody could help with the problem I have with my dishwasher, when starting the dishwasher it makes all the right noises then the lights come on saying check water supply and program end, the machine is empty and the water supply is ok, sometimes after a time the machine will work , any ideas please
    #419201
    Re: Bosch sbv50e1.10gb17 fault
    Check the filter on the water supply valve attached to the stop tap. It may be silted up?
    #419202
    Jennytom
    I have checked the inlet valve filter and the water supply, these are both ok.
    #419203
    Jennytom
    Checked the dishwasher again and have noticed a small amount of water in the sump, although it is nowhere near the water sensor probes, I completely emptied this with a sponge and hey presto the dishwasher filled and worked ok. When it finished its cycle I had to do the same again . Any ideas please.
    #419204
    Circulating pump leak? Inlet matrix? Tub gasket?…..find that leak. 😀
    #419205
    Jennytom
    Sorry for the confusion , I meant the sump inside the dishwasher not underneath. Checked underneath dishwasher and it’s completely dry, there is no leaks at all.
    #419206
    Oh what? There’s always a “small amount if water” left in the sump. 🙁
