Bosch SD13H1B running cold
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch SD13H1B running cold
  • #62154
    kapiti
    I have a Bosch S13H1B dishwasher (6 years old) and it has stopped keeping the hot water hot. The dishwasher, even on 65 degrees is cold throughout.
    Could this be the heating element? Is it worth fixing?
    Lydia
    #348949
    Re: Bosch SD13H1B running cold
    Hi Lydia,
    Can you check that model number please as I can’t see that it exists and it doesn’t look like a Bosch model number?
    K
    #348950
    kapiti
    Definitely SD13H1B…6 years old though….
    #348951
    Hi Lydia,
    Parts will be available for it. 😉
    I think it’s a GSD13*** but there’s a few to choose from, as attached.
    kapiti
    Thanks for that….it’s decided to heat up eventually but the cycle takes a few hours!!!!
    #348953
    Taking 1-2 hours is fairly normal if it’s a “normal” or intensive wash depending on the dishwasher but much more unless it’s a heavy program and you’re into the realms of something very possibly faulty. But, it can be tricky to track down if there even is a fault.
    The general rule is that if a washer or dishwasher completes the cycle without stopping or throwing up an error code there’s not going to be a fault as such.
    HTH
    gandh1
    lydia, was there an E-Nr code near the model no?
