Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Bosch SE25M851GB/79 – Check Water Light
- This topic has 5 replies, 3 voices, and was last updated 12 years ago by
richt222.
March 21, 2014 at 9:43 pm #80045
richt222
ParticipantHi All,
I’m trying to trouble shoot this, and almost at the point of giving up and just getting a new dishwasher. But as a last shot, I thought I would try posting here and see if I can collect some of your expertise!
The problem:
About a minute after starting the dishwasher, the check water light comes on. The pump still continues to fill the dishwasher with water. Then, after about 2 minutes of filling, the dishwasher starts to do intermittent draining. It will almost “pulse drain” with each drain pulse lasting about 4 seconds. Then it fills some more (about a minute or so), before pulse draining again.
When the dishwasher is filling, the sound of the water / pump moving is constant. However there is a definite cycle of bubbling sounds – bubbles for a couple of seconds, then a gap of 3 or so seconds, then bubbling again, then the gap, etc. I don’t know if this is normal or not.
(timings may not be quite accurate – all from memory!)
The digital timer never progresses, regardless of how long it is left running.
Attempts to rectify:
We had a dishwasher repair guy come and have a look, and after some poking around, said it was likely to be the main control unit board. We bought a new control unit and put it in place (£100 down). Unfortunately made no difference at all.
I spent some time looking at it myself today. Took the filters out, accessed the impeller (turns freely) and lifted the rubber non-return valve out. No problem that I could find there. Felt around for any chipped china etc. Nothing.
Took the side off and checked that there were no blockages in the drain pipes. I was able to blow through the drain pipe freely (when the non-return valve was removed). I ran the dishwasher with the side off, and could observe the water flowing in freely and seemingly being expelled freely.
I’m now a bit stumped as to what to check next. Would be great to get some pointers!
I could possibly post a video if it would help. But would be good to have some other things to check at the same time.
Thanks in advance!
Richard
March 22, 2014 at 4:00 am #411467Simon46
ParticipantRe: Bosch SE25M851GB/79 – Check Water Light
Impellor jug required by the sounds of it.
Meters the exact amount of water going in.
Unplug power if youre going in.
Regards
SimonMarch 22, 2014 at 7:13 am #411468Martin
I agree you’ll need to buy and fit one of THESE
It’s a SIEMENS machine by the way and not a Bosch.
I hope you didn’t pay the guy for that Module Board but if you did you are entitled to a refund under the Trade Descriptions Act 1968. 🙁
March 22, 2014 at 10:06 am #411469richt222
Thanks guys! I will get one of those ASAP, fit it, and report back.
Unfortunately, we bought the control module board ourselves. The guy offered to buy it, but for £60 more than we could buy it privately. Ah well, live and learn.
Thanks once again. I’m actually excited to try the impeller jug and see what happens! 🙂
April 20, 2014 at 11:24 am #411470richt222
Just wanted to report back… This did fix it! Thanks once again.
April 20, 2014 at 11:38 am #411471Simon46
Well done and happy dishwashing
Simon -
