Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Bosch Serie 2 oven adhesive strip
- This topic has 10 replies, 5 voices, and was last updated 5 years, 6 months ago by
wmda99.
September 13, 2020 at 1:10 pm #98340
wmda99
ParticipantHi,
I recently bought a Bosch Serie 2 oven. It came with a self-adhesive strip which I’m not sure what its for.
I can’t find any mention of it in the manual. Am I supposed to stick it across the top of the door- and if yes, what for?
I’ve never seen this with any of my older ovens…would appreciate any advice!
Thank you.September 13, 2020 at 3:28 pm #471963electrofix
Moderatorit wont be part of a door seal as this would already be fitted
its more likely to be to fill a gap during installation
if you had posted a model i could have looked to see if i could see it in the manual
September 13, 2020 at 6:49 pm #471964wmda99
ParticipantHi Dave,
Its the [h=1]Bosch Serie 2 HHF113BR0B bought from John Lewis.[/h] I’m more curious than anything else really!
And of course I’d like to know if i should hold onto it or not…Thanks!
September 13, 2020 at 7:20 pm #471965electrofix
Moderatorshort answer have not got a clue
its not in any instructions i can see
would need to see what its made of and the size to have any idea
[USER=”125″]don[/USER] have you any idea ?
September 13, 2020 at 7:27 pm #471966don
ModeratorIf it’s foam then it could be an anti condensation strip similar to dishwasher ones which would be fitted under the worktop.
Best thing to do [USER=”57824″]wmda99[/USER] is to post up a photo.
Don
September 13, 2020 at 7:29 pm #471967Popup
ParticipantIt wont let me upload a picture atm not sure on any of size.. size of?
September 13, 2020 at 7:37 pm #471968electrofix
Moderatorbecause of server constraints you have to host the pic on another server like google pics then post a public link
September 13, 2020 at 11:50 pm #471969wmda99
ParticipantI’ll try do that. I admit I’m not very technical though
December 14, 2020 at 8:14 pm #471970jaymidd
ParticipantI have the exact same model. The strip sticks along the top edge of the brushed stainless steel fascia and will seal any gap between that and the underside of the worktop/housing the oven sits in. Hope that helps.
December 14, 2020 at 8:21 pm #471971jaymidd
ParticipantAs a follow up to my previous reply, are you able to shed any light on the separate query I’ve posted (pasted below):
Bosch Serie 2 HHF113BR0B. Only had this oven for 6 weeks. I think there is a problem with the cooking fan at the back of the oven. After switching the oven on and setting a temperature, it takes about 20 mins before I notice the fan start to spin. Does anyone know if this is normal? I would expect the fan to start up immediately, or at least once the oven gets to temperature. I believe this model is what’s called a ‘forced fan’ oven, with the heating element surrounding the fan in the rear panel. I’ve noticed the element glowing bright orange while heating up and am worried about it burning out. Shouldn’t the fan spin all the time to simultaneously cool the element?
I can’t see anything in the manual about this, I look forward to your thoughts.
Many thanks
December 14, 2020 at 8:34 pm #471972electrofix
Moderatorthat does sound wrong
if the circular element is energised the fan should be as well
some cookers turn the fan off with the element these days because of energy consumption ##
you need to ring and aske them
