Bosch Serie 6 ongoing issues
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch Serie 6 ongoing issues
  • #95777
    Naomi Draper
    Hello all,
    I’ve just had a new pump fitted but prior to that had the following issue: cycle got diwn to 2 mins spun then would revert to 12vmins, then keeps doing so.
    Engineer came out, ran through foxes, replaced pump ran a test spin and drain, and all good.
    Now, it’s not draining at all but I can even heat the click when it moves from rinse to spin, just going round and round full of water as if on a wash cycle. Please help, its 4 years old, I did worry it was pcb due to the odd behaviour its doing, many thanks Naomi
    #461338
    well you would need to check if the pump was working. If you cancel prog and select spin does it pump then ?
    Naomi Draper
    Nothing happening pump wise not even engaging just replaced the pump this morning. Thank you
    #461340
    lost now
    does that mean its ok now or
    you have replaced the pump this morn that was previously replaced by the engineer ?
