Bosch sg 3062 taking 3 hours to complete cycle
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch sg 3062 taking 3 hours to complete cycle
  • #64444
    bathtub tom
    The problem seems to be the pre-rinse part of the cycle that can take over an hour,everything seems OK after that. The rinse and hold works fine. It takes water and pumps it around OK – for over an hour!
    It’s ten years old!
    #357102
    Re: Bosch sg 3062 taking 3 hours to complete cycle
    Probably not heating then bathtub. Could be a costly fix my friend. 🙁
    #357103
    bathtub tom
    Heat the pre-rinse? I’m sure its not supposed to. It heats the main wash and final rinse OK.
    #357104
    Dicky timer then maybe bathtub? Have you checked out the machine? Has it been looked at by an expert at any time in the last 10 years? Could be anything you or I care to guess at this point in time without serious physical intervention. The symptoms aren’t sufficiently specific toward a more accurate diagnosis I’m sorry to say. 🙁
    #357105
    bathtub tom
    I’m leaning towards the timer as well. I stood and watched it earlier this evening, the blasted thing ran perfectly.
    Is it a known fault?
    I’ll start dismantling it tomorrow with the WD40 handy.
    #357106
    bathtub tom wrote: with the WD40 handy.
    :rolls:
    Please don’t spray anything inside the machine with WD40.
    #357107
    bathtub tom wrote:Is it a known fault?
    Not one I’ve come across anyway. However it could be that the timer knob has got engrained with spillages (i.e coffee or tea stains) and the sticky goo between the knob and fascia panel makes the knob stiff to turn. A tiny squirt of WD40 around the knob will disperse it for sure. 😀
