Good morning,
Wondering if anyone can offer some advice on a problem with the above m/c?
The m/c will not allow water to enter, and remains in the pump out/safety mode.
When I came to test the inlet valve, rather than the usual style of valve, the one fitted is disc shaped which I believe is the inlet valve.
Could someone confirm this, as I may be mistaken; perhaps the disc valve is a separate unit, and the inlet valve is located elsewhere.
Also wondering if the aqua stop system has activated, but don’t know how to test this. Perhaps I should replace with a normal inlet hose to ascertain?
There are no error codes or flashing lights.
jontymox
