Bosch SG43A2GB/01
  • #14554
    squadman
    Anyone had any experence with the above appliance, I have a intermittant filling problem. The appliance has no pressure switch and looks very simple. The inlet soloenoid being coupled directly to the DA Chamber and then to the sump. When the appliance does work it fills until the recirc pump operates and then fills to its working level.
    When the machine malfunctions it fills until the float switch operates the drain pump, does the filling process operate from the timer i.e timed fill ?
    Thanks 😕
    #159884
    Re: Bosch SG43A2GB/01
    Take out and clean the fill magnet/float unit in the tub (make sure you put it back the correct way round though) 😉
    #159885
    squadman
    Martin, thanks for your help on this one I dismantled the magnet assembly as you suggested and cleaned the chamber in which it operates. This cured the fault I had not noticed the magnet/reed arrangment which is a variation on a theme is it not.
    Cheers !
    Squadman 😀
    #159886
    gegsy
    Hi squadman,
    Can you please check your model number, as some models have had a software change in the control board and change to the flood mushroom assembly to combat this fault along with the sticky float which has now been disused in recent models.
