Yes, the older models use this float, some use the electronics to time the fill and then the rest use that flow meter/impeller jug.
Given the build age of your one its recommended to change the safety system assembly (mushroom shaped thing in base) also, p/no 490618.
gegsy wrote:Hi
Thanks for the advice, what would be the problem with this?
They were problematic, along with the float causing flooding.
Might as well get it done, saves you getting call back blaming you that its flooded now since you been :rolls:
Thats the best of my knowledge, just wait for a BSH guy to confirm or flame me before you order 😉 😆
