Bosch SGI43EQ5 dishwasher bottom spray arm not rotating
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch SGI43EQ5 dishwasher bottom spray arm not rotating
  • #45564
    boselecta
    Bosch SGI43EQ5GB dishwasher
    The top spray arm was not rotating on this machine so I replaced the ditributor and heater unit, just had a recall two days later now the bottom spray arm is not rotating!.
    Checked and no water is spraying throught the bottom spray jet. Could this be a faulty distributor or is there something else I should be looking at?
    #286189
    nomadPaul
    Did you check the IC on the control module ? Sometimes if the diverter valve goes , it takes out the chip on the main board .You can see the top of the IC broken off if this is the case .
    I’d also look to make sure the new heater was seurely fitted and not leaking onto the diverter motor from one of the seals .
