bosch sgi5345gb/01 sicasym
  • This topic has 5 replies, 2 voices, and was last updated 15 years ago by MDE.
  • #61987
    MDE
    Hi all, Revisiting an old topic with this one. I ordered a
    module [p/n 489607] for this machine and when it arrived there was no coding instructions in the box and so i have a couple of questions and I hope someone can help thanks.
    1- Would someone be able to send me a coding sheet.
    2- With this model number, do I need to do the wireing change
    {I think I do but would like to know for sure}.
    Thanks Mark.
    #348260
    MDE
    Re: bosch sgi5345gb/01 sicasym
    Me again
    I have a coding sheet from another bosch module {p/n493323} would anyone know if it would be the same, the module looks the same. ❓
    The earlier post I was referring to was [sgs4468gb/35] and it is in Trade Technical Enquiries,sorry don”t know how to link it.
    Mark.
    #348261
    MDE wrote:1- Would someone be able to send me a coding sheet.
    Email me your address and I’ll send you the correct coding sheet. 😀
    MDE wrote:2- With this model number, do I need to do the wireing change
    I doubt it but if you give me the 4 digit FD no I can double check for you while I’m at it. 🙂
    #348262
    MDE
    Hi Martin, I went back and had a look but the FD no. has been wiped off and is not on it anywhere else. Is there any other way to tell.
    #348263
    MDE wrote:Hi Martin, I went back and had a look but the FD no. has been wiped off and is not on it anywhere else. Is there any other way to tell.
    I’ve double-checked on this for you and YES you do need to do the wiring link and switch off sicasym. Your machine is an SGI5345GB/01 and the last 2 digits (i.e 01) means it is a KI01 and hence needs converting.
    #348264
    MDE
    Thanks for the coding sheet Martin,I did the repair on Saterday all worked. But not a repair I like doing.
    Mark.
