I have a Bosch SGI 53E25EU and I have a problem. When I used it, there was a kink in the drain hose. According to the manual maybe the pump is blocked. (there is not any obstruction in the drain or disposer)
I can start/stop the programs, LEDs are show me the correct status, but the machine doesn’t work. How can I reset this blocking?
This model of Dishwasher is not available here in the UK. I suspect therefore you are also not in the UK? Sadly, I do not know the correct ‘reset’ procedure for that model because of this 🙁
Please try looking over the Bosch website for your country and maybe you can get an Instruction Book that way :tup:
There is always the reset procedure in the short manual (should be). Normally this could be holding down the on/off button for 3 seconds as it is insribed on the fascia or holding two buttons assigned as reset on a front panel (after turning the machine on with main switch) or for machines with new N and O controllers rotating the knob respectively on Reset position while machine is tuned on (see inscription on fascia).
