BOSCH SGI57M05GB complketes cycle , doesn’t empty
Home Forums Public Support Forums Help And Support Dishwasher Help Forum BOSCH SGI57M05GB complketes cycle , doesn’t empty
  • #85163
    carrosa
    I’m hoping somebody can help me…
    I have recently replace the in-line water heater on my SGI57M05GB as the machine was stopping on the rinse cycle and not heating the water. That problem is now fixed, however, I now have another problem which I can’t figure out…
    Now the dishwasher completes its wash-cycle “normally”, however once the cycle completes ( timer runs down to 00 and it stops ) the machine is still full of water… It is all clean and free of debris throughout and there are no blockages. If I trip the float switch manually it empties perfectly.
    any ideas ??
    Thanks !
    #427917
    Re: BOSCH SGI57M05GB complketes cycle , doesn’t empty
    If the pump worked OK before the heater change then I would think a wire has come adrift?
    #427918
    carrosa
    the pump works when I manually trip the micro switch on the float… I can’t see any loose or missing connections around that area… any idea where else I could look ??
    #427919
    The question I set was, did the pump operate normally PRIOR to the heater change?
    #427920
    carrosa
    yes, the pump all worked, the only thing wrong PRIOR to the heater change was cold water and the cycle not progressing past rinse…
    #427921
    That being the case then a wire/connector block has probably got displaced. Time to check and double check all connections.
    #427922
    carrosa
    ok, thanks ! I’ll get onto it
    cheers
