Bosch SGI6625GB/13 d/w clonking
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch SGI6625GB/13 d/w clonking
  • #6709
    streetlighter
    Hi again
    I have a new stile bsh d/w sgi6625gb/13
    When it fills it clonks from fill to pump out very fast. (but still fills)
    last time i hade one of these i changed the softner but it didn’t improve much so i turned down the water presure.
    Is this something simple like blocked sump hose or should i be looking at ordering new floaty fill thingys. sorry float chamber/regulator
    or could it be the softner this time?
    paul
    Sham I cant find a sleeping emoticon.
    #119175
    sparkey
    Re: Boshe d/w clonking
    Streetlighter, check the hose from the pressure chamber to the sump, If this gets restricted the water will not get into the sump quickly enough causing water level to build up in the safety chamber tripping the overfill switch which turns on the drain pump.
    Regards
    Sparkey
    #119176
    streetlighter
    Thanks sparky
    Got to go back tomorrow to look at her ovn, check this then. Didnt have time to pull out an integral d/w today. let you know the outcome.
    Ta
    paul
    #119177
    Re: Bosch SGI6625GB/13 d/w clonking
    Streetlighter,
    As Sparkey says it’ll be a Pressure Chamber to sump problem. If the tube isn’t blocked with fat sediment it will be the pressure chamber limescaled up (I bet the customer is not using salt) 😉
