Re: Bosch sgs 3042GB dishwasher -water not circulating?
Yep, drain pump and circulation pump. After approx 1 min of fill, you should hear the circulation pump cut in. If you can hear the pump running but have no circulation, the machine is underfilling (a common problem with this range). A faint humming noise would indicate that the pump is jammed or that the start/run capacitor is no longer kicking the pump into action.
If you’re going into the machine, pull the plug first. :plug:
Pebguin45.
