I have a 6 year old Bosch, and its been fine until recently. Now after a normal wash cycle dirty water is left in the bottom, about a 1cm above the mesh plate. I have read the post on here and removed the black rubber flap, and re-seated it. I have also checked the impellor, and that seems to spin with no obstruction. I removed the side of the machine, and the clear tubing is visible; when the machine empties the waste water can be seen moving although not that much. If I pull on the red rod at the bottom, which seems to start the machine emptying, again the waste water seems to struggle to escape. I was wondering whether there is a way of removing the bottom of the machine so I can inspect the pump – maybe there is an obstruction. Can anyone help?
Cheers
