Hi guys
Got above machine to look at custmors says on quick wash it occasionally heats but no heat on any other program and it never ends any of them just keeps running. could this be module fault. any help would be great thanx
And it’s easy to drop the module out and check for that tell-tale PCB burning 😉 Don’t forget the easy check to see if the module is terminal though before mending the burn (well documented by me and others on the subject of course)
Also check the Pressure switch/Meter Tank unit 🙂
