Had this dishwasher for 7 years now but last night i noticed the pump was still running after about 3 hours, the dishwasher had done its cycle including drying but still the pump was running. I noticed a dot in the bottom right hand side of the display plus bar indicating it was rinsing, i pressed the reset buttons which brought up the 0 but the dot was still there and it kept pumping even after 5 mins. Any ideas or is it time to part company with it. ❓
Sounds like the base has water in it so the antiflood device has kicked in
where it just pumps out all the time.
Pull the plug out and draw the machine forward and caefully tilt the machine backwards to an angle of about 45 degrees and see if water comes out of the back of the machine.
Ive just tried this what you suggested and no water came out from base. But what i did notice on display was that there is just the dot and nothing else showing when pump is pumping.Any more suggestions cos the scrap yard is fast aproaching
