I have what was the top of the range bosch dishwasher. Just out of warranty as usual. The problem is that on most cycles (70 degrees is the only one that seems to work now) it will run through and get to 1 minute to go and never go to zero. The dishes are clean but usually still wet. The program seems to have completed ok but just not finished off. I’ve tried the reset program but the next time it still does it. As I said 70degrees works fine, but eco etc don’t.
Any ideas? Is this a common known fault.
Thanks,
Nick.
