Re: bosch sgs 8812gb/35
eng14 wrote:the fitting instructions to do a mod it not very clear what they want.
I think you’ll find them pretty straight forward TBH. Firstly check the symbols on the ‘coding sheet’ that match the machine you are fitting the module to. There are 5 to choose from those illustrated, find your match then note the display code number 25. 26.27.28 or 29. That’s the display window code that you need to select.
Now whilst holding the last 4 buttons in together you switch on the machine. (Best to do that with the module plugged in but NOT fixed in the fascia otherwise you cannot access that all important 6th button.:wink:). Then release those 4 buttons you will see the code number in the display window, if it’s not the one for the model you have simply keep pressing the 3rd button to get the number you need. Once selected turn the machine off and the coding is stored..how easy it that eh? 😀 😉 8)
Simples!
