Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch SGS0902GB/04 FD8010 Dishwasher
- This topic has 6 replies, 5 voices, and was last updated 20 years, 2 months ago by
mike412.
February 1, 2006 at 7:22 pm #15300
mike412
ParticipantHi Guys.
One for the Bosch Experts.
Went to this d/w today, customer out key under mat job, found customer had left “post-it” notes.
(1)”Autowash taking 2hrs30mins.” (I noted that a the display indicated
that it was going to take 2hrs44mins, but I dont know what the “norm” is for that programme.)
(2)”Quick wash programme not functioning properly- cycle does not finish.
needs to be done manually and does not drain properly.” (I tested for draining and 2-3 cycles pumped out fine).
At this point husband came home and added”the cycle times keep randomly reselecting themselves”.
I have not seen this model before, its got a module in the base, r/h side.Any ideas would be appreciated.
Many Thanks
MikeFebruary 1, 2006 at 7:52 pm #162991Martin
ParticipantRe: Bosch SGS0902GB/04 FD8010 Dishwasher
After checking the ‘usual’ causes (i.e crud in pressure chamber to sump hose, pump chamber and non return valve clear, heater working and spray arms circulating loads of water etc) Then it could be the turpidary sensor playing tricks and often a good flush through with a dishwasher cleaner a couple of times may cure?
I trust they are putting salt into the thing are they?
February 1, 2006 at 8:25 pm #162992mike412
Thanks Martin for prompt Reply.
I will follow up on all these points. One “post-it” message from customer
which I did not post earlier was ” have used two packets of descaler in last couple of weeks”. If the Turpidity sensor is still suspect is there any way of cleaning this or is replacement the norm?.Cheers,
Mike.February 1, 2006 at 10:37 pm #162993gegsy
For your info, autowash is the only programme that utilises the turbidity circuitry.Greg
February 6, 2006 at 8:40 pm #162994mike412
Cheers Guys.
Just as a matter of interest, can someone advise the approved way of emptying the water tank on this series of d/w, in order that it can be moved to give access to the float assembly?.
Thanks,
MikeFebruary 6, 2006 at 10:28 pm #162995aqualectric
Turkey baster!!! Works a treat, gives the customer a laugh, everyone’s a winner!! 8) 😉
February 6, 2006 at 11:04 pm #162996Simon46
Expect loads of p**staking when you buy one in supermarket though 😆
S.
