Hi, ive got a problem with the machine, when i open the door during the wash cycle it drains the water away then doesnt refill, it just steams up, seems to be ok if the door is opened during the rinse cycle, its an electronic model, i was wandering if a reset would help, not sure how to do it, thanks in advance,
Could always suggest not opening the door in the first place.:wink:
If you are opening it when the water is hot, on start up it may bubble up to a high level tripping the anti flood hence the pump out. Would have thought it would re set after that though. Other than that, could be a tricky one to solve.
thanks for the reply, guess what, it has started working again, the only thing is the top spray arm only turns during the wash cycle not rinse, is this normal for a dishwasher,
